Enables the soft input reset feature.
all | Specifies that the configuration applies to all neighbors in the specified address family. If no address family is specified, the configuration applies to the IP Unicast family on all IPv4 peers. If an IPv4 address family is specified, the configuration applies to all IPv4 neighbors. If an IPv6 address family is specified, the configuration applies to all IPv6 neighbors. |
remoteaddr | Specifies the IPv4 or IPv6 address of a BGP neighbor. |
ipv4-unicast | Specifies the IPv4 unicast address family. |
ipv4-multicast | Specifies an IPv4 multicast address family. |
ipv6-unicast | Specifies the IPv6 unicast address family. |
ipv6-multicast | Specifies an IPv6 multicast address family. |
vpnv4 | Specifies the VPNv4 address family for Layer 3 VPN support. |
Disabled.
If no address family is specified and an IPv4 address is detected, IPv4 unicast is the default address family.
Before you can change the configuration with this command, you must disable BGP, and you must disable the corresponding BGP neighbor session using the following command:
disable bgp neighbor [remoteaddr | all]To enable this feature on Layer 3 VPNs, you must do so in the context of the MPLS-enabled VR; this feature is not supported for BGP neighbors on the CE (VRF) side of the PE router.
This command applies to the current VR or VRF context.
If you do not specify an address family, this command applies to the IPv4 unicast address family. To apply this command to an address family other than the IPv4 unicast address family, you must specify the address family.
For an IPv6 peer, an IPv6 address family must be specified, because an IPv6 peer does not support IPv4 address families. If no address family is specified for an IPv6 peer, the default, the IPv4 unicast address family, applies and the command fails. Similarly an IPv4 peer only supports IPv4 address families and the command fails if an IPv6 address family is specified.
The following command enables the soft recognition feature:
enable bgp neighbor 192.168.1.17 soft-in-reset
Support for IPv6 was added in ExtremeXOS 12.6 BGP.
Support for Layer 3 VPNs was added in ExtremeXOS 15.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
